42-61
62-81
82-101
102-121
122-141
142-161
162-181
182-198
Voronoi.v.1.1.2018.03.07
Added X button. Double click this button to reset a diagram.
Added Filter slider. Use it to remove extra small sides of polygons.
http://moi.maxsm.net/item/48
Thank you very much Max!!
Are you running for a prize ? :)
It seems that this Voronoi plugin is a sort of personal challenge for you.
Great job, great job Max!!!
Only a question, if I may...
I did some test but I can't figure out how the new "Filter" affects the output of the Voronoi.
Could you please write something about it ?
Thanks again.
French Version Updated! ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Hi Marco
No, it's not a challenge. I just want to make a good script and then forget about it.
It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider.
Ciao Max!
@You : "...It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider..."
Perfect! Got it.
Tested and now is...perfect!!
@You : "...I just want to make a good script and then forget about it..."
OK! Then you can sleep soundly :) You created an
AMAZING script.
Thanks a lot for all your effort.
Ciao!
Max...your wanderful script gave me an inspiration..."How to brake in two each Voronoi cell and make a funny thing"
Look at this video :
http://take.ms/pBFZS
In short the process I have used is :
1 Select all Voronoi curves
2 Apply the "mark curve start" plugin
3 Select again all Voronoi curves
4 Apply the "mark curve middle point" plugin
5 Trim the Voronoi curves with the generated points of steps 2 and 4
6 Close all the "half curves" with the command "closecurve"
You can download all the plugins I've used at :
http://take.ms/uAgYy
Unzip and copy the files into the Moi's "commands" folder.
THOSE CUSTOM COMMANDS WHERE TESTED WITH MOI V3
I suppose they should work also with Moi V4 but I didn't try)
Ciao!
P.S....forgot to say that I've used also another Max's custom command : "PatternSelection"
You can grab it here :
http://take.ms/0F9I8
Ciao!
I was waiting for this moment sooo long. Now your script is perfect, just perfect! Thank you very much!
Hello everyone!
I admit I was tempted to create on the fly a brand new thread but I want to submit this thought to all "colleagues" moiers :)
The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
I think it should deserve much more than this but anyway...tell me what do you think ?
Best thanks is use the Max's scripts! ;)
Yes Pilou!
You're right...but I think that maybe a public thank could b a nice thing for him....I don't know :)
Thanks Max!
With the little trick above :)
http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.81
(2 different grids Isected then ExplodeMoved: one with Corners =0, other Corners = 100 )
PS Subdiv (not applied here) don't works with all volumes ( surely some > 5 polygons! )
Very nice!
A sort of "fragments of an exploded planets" :)
Is it possible to add a file of points, as input to the voronoi script?
Hi Brian
you can use ImportPointFile script (
http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
<< select points and run voronoi script
So... :)
Alberto
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
42-61
62-81
82-101
102-121
122-141
142-161
162-181
182-198
