Full Version: Scherk's second minimal surface script
Show messages:  1-18  19-34
17 Jul 2017   [#19]
The Scherk1 surface can be copied/moved, by PI units in the x direction and also PI units in the y direction, checkerboard fashion.
PI (+/-), is the length of an unwrapped circle of diameter 1 unit.
I read that the Bonnet transformation, with theta = 90 degrees, turns a Scherk1 into a Scherk2 surface. (?How to script?:-)
(Also applies for catenoid/helicoid, and for D, gyroid, P surfaces...)
17 Jul 2017   [#20] In reply to [#18]
>>I've no idea if it can be modified to make nurbs<<
Very interested in hearing more about
18 Jul 2017   [#21]
Mike;
>>I got an .obj file from MathMod and then made it solid in MeshMixer.<<>>One possibility would be to use retopology tools in 3D Coat or something like Topogun to get a quad polygon layout and then use Max's sub-d to NURBS script to convert that to NURBS.<<
is it opssible in Meshmixer to go form triangle to quads `liKe Michale suggested ?
19 Jul 2017   [#22] In reply to [#20]
I have constructed a Sherk tower manually but the blends are not really smooth.
Is there a way to expand the Scherkscript so it will stack up saddles to build a tower ?
19 Jul 2017   [#23] In reply to [#22]
This is the base unit, for Scherk2 tower, resulting from previously described lineweb, blends, trims, etc.
Just Stack and rotate appropriately.
The complete minimal surface goes to infinity at the poles, I think, precluding a simple "complete" script.
The 7Z file is about 1/3 the size of the .zip file. The 7zip unzipper is a free program.
ScherkModule06.7z
19 Jul 2017   [#24] In reply to [#23]
Oh very helpful Brian, thank you very much !
Are you familiar with 3D FX graph ? Is it possible to
get it working with the fomula of a Scherk tower ?
19 Jul 2017   [#25] In reply to [#24]
Hi Tom,
Let u = r, the radius, which ranges from 0 through 1.
Let v = theta, the angle, ranging from just over 0, to (just under) 2PI ~= 6.2831253.
I tried the script equations with ln, sin, cos, and atan, which mostly reproduced the surface, with some problems with poles v = 0 and v = 2PI.
Using your implicit equation with sin, sinh(x) and sinh(y),
it becomes tedious to enter the equations into the fxgraph3d lines, so I've run out of time...
Best to write the equations in notepad++, as a .js file, and copy them over...then the parenthesis at least can match.
I set u = r and v = theta, as above, which I am not sure is right, but...
set x = u*sin(v)
set y = u*cos(v)
note that sinh(x) = (exp(x) - exp(-x))/2
z = asin((exp(u*sin(v))- exp((-1)*u*sin(v)))/2 * (exp(u*cos(v)) - exp((-1)*u*cos(v)))/2)
Does not work :-(
20 Jul 2017   [#26] In reply to [#25]
Thnak you Brian, as I see it is not easy I will see if I succeed !
20 Jul 2017   [#27] In reply to [#26]
For the Scherk2 surface, the equation of a hyperbola in quadrant 1, with vertex at radius of 1 unit, is x*y = 1.
Points (x,y) which produce a z value are contained within the 4 hyperbolic curves.
(In contrast, the Scherk1 surface has a rectangular x,y source, so it was easier to program.)
I think that FXGraph3D could use a numpoints input(?)
20 Jul 2017   [#28] In reply to [#27]
For a mathematician layman what you say is a bit like a Mandarin dialect ;-)
But I am trying to decipher your explanation !
20 Jul 2017   [#29] In reply to [#28]
https://en.wikipedia.org/wiki/Hyperbolic_function
For a hyperbola, angle theta is not used, instead u is used, and is an area.
(For a circle, angle = 2*Area, so either can be used.)
http://www.clayton.k12.mo.us/cms/lib/MO01000419/Centricity/Domain/241/ArticleHandout.pdf
24 Jul 2017   [#30]
The implicit equation did not work out very well, due to "poles," but here is the classic Weierstrass parameterization, as per Wikipedia.
The surface which results is the same as for the _Scherk2 long .js, .htm script, but lacks symmetry at two ends,
at least partly due to the lack of numpoints parameter in _FXGraph3d (?). So I prefer the long script, after processing, for the Scherk tower approximation.
The FXGraph3d version comes in two halves, due to the exclusion of zero, and replacement with .0001.
The .8 can be increased in value, if U and V count are increased.
The two halves can be networked and joined, offset, edge swept, and joined to a solid, for a super "pringle". A few Fillet tries did not work.
Scherk2WFirstHalf01
_FxGraph3D log((1+u*u+2*u*cos(v)) / (1+u*u-2*u*cos(v))); log((1+u*u-2*u*sin(v)) / (1+u*u+2*u*sin(v))); 2*atan((2*u*u*sin(2*v)) / (u*u*u*u - 1));0;0.8;0.0001;3.141592653589793;21;21;1;;;UV
Scherk2WSecondHalf01
_FxGraph3D log((1+u*u+2*u*cos(v)) / (1+u*u-2*u*cos(v))); log((1+u*u-2*u*sin(v)) / (1+u*u+2*u*sin(v))); 2*atan((2*u*u*sin(2*v)) / (u*u*u*u - 1));0;0.8;0.0001;-3.141592653589793;21;21;1;;;UV
24 Jul 2017   [#31] In reply to [#30]
Unbelieeeeeeeeeeeevable !!
How did you manage to out this formula together ... hats off
and thank you very much, Brian !!
24 Jul 2017   [#32] In reply to [#30]
Thanks a lot Brian!
Very handy formula!!
Mathematics, this almost unknown "savage beast"...for me! (sigh)
Bye!
24 Jul 2017   [#33] In reply to [#31]
Thank's Tom and Marco.
The equations, as shown in Wikipedia, https://en.wikipedia.org/wiki/Scherk_surface, are the same as in the Scherk2 script.
The equations are the comprehensible result of some mathematician managing to integrate the nearly
incomprehensible Weierstrass–Enneper parameterization.
https://en.wikipedia.org/wiki/Weierstrass%E2%80%93Enneper_parameterization
For some other minimal surfaces, like Costa and Gyroid (I think), the integration must be done numerically, programmed with some
program like Mathematica. The programs create a triangle mesh, not NURBS.
This Half version looks better, and uses zero. It can be Networked.
Scherk2WWalfToRotate01
_FxGraph3D log((1+u*u+2*u*cos(v)) / (1+u*u-2*u*cos(v))); log((1+u*u-2*u*sin(v)) / (1+u*u+2*u*sin(v))); 2*atan((2*u*u*sin(2*v)) / (u*u*u*u - 1));0;0.8;0;3.141592653589793;24;48;1;;;UV
24 Jul 2017   [#34] In reply to [#33]
"nearly incomprehensible Weierstrass–Enneper parameterization"
From my perspective, what you have posted already looks pretty sophitiscated ;-)
Downloaded the last version- Thank you very much !!
