Full Version: [script] Morph between two curves
Show messages:  1-19  20-29
19 Dec 2013   [#20] In reply to [#19]
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
20 Dec 2013   [#21]
Cool plugin but something curious! :)
Line Web: http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
20 Dec 2013   [#22]
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
20 Dec 2013   [#23] In reply to [#21]
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
20 Dec 2013   [#24] In reply to [#23]
This is really cool Max, thanks for posting it and updating it!
29 Dec 2013   [#25]
Cool! ;)
21 Mar 2018   [#26]
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
21 Mar 2018   [#27] In reply to [#26]
Hi Jopo
you need to download a latest version of the script: http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
24 Mar 2018   [#28] In reply to [#27]
Hi Max,
thanks a lot! It's working now.
JoPo
10 Mar 2024   [#29]
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
