Full Version: [script] Morph between two curves
Show messages:  1-15  16-29
16 Dec 2013   [#16]
Good tip, picking the discards was adding unnecessary work!
Thanks Michael!
16 Dec 2013   [#17]
Very cool Max! Thanks for a great script!
Michael T.
16 Dec 2013   [#18]
Wow this script looks awfully useful!
Many thanks for providing this!
19 Dec 2013   [#19]
Great script! However, sometimes a morph between two closed curves yields several intermediate morphed curves that are open instead. Which makes it difficult to use for further lofting, as it is very hard to find the open spot (I know there's a script for that too). Maybe could be improved? Thanks!
19 Dec 2013   [#20] In reply to [#19]
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
20 Dec 2013   [#21]
Cool plugin but something curious! :)
Line Web: http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
20 Dec 2013   [#22]
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
20 Dec 2013   [#23] In reply to [#21]
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
20 Dec 2013   [#24] In reply to [#23]
This is really cool Max, thanks for posting it and updating it!
29 Dec 2013   [#25]
Cool! ;)
21 Mar 2018   [#26]
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
21 Mar 2018   [#27] In reply to [#26]
Hi Jopo
you need to download a latest version of the script: http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
24 Mar 2018   [#28] In reply to [#27]
Hi Max,
thanks a lot! It's working now.
JoPo
10 Mar 2024   [#29]
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
