15-29
Hi danperk, also for doing that kind of hatching trimming, you can use curve booleans as a shortcut instead of using Edit > Trim which it looks like you're doing there.
Start with all the hatch lines selected:
Run Construct > Boolean > Intersection, then select the closed curve region boundaries. That will then generate a result like this:
The lines will be cut by the boundary and only the parts of the line that are on the active area of the 2D region will be kept.
If you want the other way, use difference instead, that will slice away the stuff inside the active 2D region like this:
You can use Trim too, the booleans just basically automate the picking of which pieces to discard or keep.
Good tip, picking the discards was adding unnecessary work!
Thanks Michael!
Very cool Max! Thanks for a great script!
Michael T.
Wow this script looks awfully useful!
Many thanks for providing this!
Great script! However, sometimes a morph between two closed curves yields several intermediate morphed curves that are open instead. Which makes it difficult to use for further lofting, as it is very hard to find the open spot (I know there's a script for that too). Maybe could be improved? Thanks!
I used lines (opened curves) to build morphed curves. But now the script uses different method in situation when both curves are closed. It uses circles instead. :)
Thank you for advice.
Cool plugin but something curious! :)
Line Web:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3666.10
So it's you or Michael who have made an inversion! :)
I presume it's you for any secret reason! :)
(not a big deal as the Flip Command exists in Native in Moi : just select a curve(s) and Press Tab then type Flip! :)
I first use CMorph between the 2 yellow curves then LineWeb! Careful! Order of select curves is important for LineWeb!
It works, thanks Max! Only thing left now is the flipped curve direction as Pilou mentions.
Ops. Just forgot to check this :)
Found. Fixed. Uploaded.
This is really cool Max, thanks for posting it and updating it!
Cool! ;)
Hello Max
in Moi V4 on my Mac I get this error message when I run the script. In V3.1 it's working fine.
cheers
jopo
Hi Jopo
you need to download a latest version of the script:
http://moi.maxsm.net/files/scripts/cMorph.v.1.1.2014.01.19.zip
Hi Max,
thanks a lot! It's working now.
JoPo
I'm usually not very active here but I had to tell you: THANK YOU! This helped me save at least an hour of work!
15-29
