19-38
39-48
Hi Burr....
Are you working on modify moi.css for us ? :)
When it will realease.....
Cant wait for it...
Thanks !
Hi Anis,
Then you can start to get stuff like this:
But I probably wouldnt be doing anything like this with MoI. I'm not very artistic and wouldnt make much of a UI designer. After the release, I'm sure a few will pop up though.... Pilou has an eye for these things and used to change his "daily"! There were a couple others like Ash that were pretty good at this... I'de wait for them to chime in when all is said and done...
While the betas are changing so often, it really is a waste to invest any amount of time in it, as things can change from one month to the next and you cant expect that all your work will just "migrate", so we'll just wait for the release.
< Pilou has an eye for these things and used to change his "daily"!
oh no It's not me! I change just Option French / English!
I prefer original ! it's Zen! And I want peaceful quiet image!
Because I have yet this all the day! :)
I guess I just remember this stuff changing daily!
Ah yes!
It's different ;)
It's just Copy screen inside 2D prog for publishing! ;)
It's not new UI :)
Hi Burr,
Thanks for filling me in on the source of the color icons. I kind of like them. I did try the custom UI's during MOI's version 1.0 phase, but I found I'm not very adventurous when it comes to customizing the look of MOI. I think the simplicity of the UI is one of the things that makes it so good.
Jesse
Hi Jesse,
I agree. I seem to make it worse! I think some like to make it look like their other apps. I dont already have a preference though. I liked Lyes' icons and kept them though.
It seems that Lyes has left the forum? Too bad. His helmet modeling video was a real awakener for me!
What is/are the best way/s to write something around the lateral surface of a cylinder?
...the flow command:
http://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
I had tried flow command and it did not provide my desired effect first that is why I asked :)
Tanx to your hint, I realized that I had made a mistake and by rectifying that mistake I was able to use flow command to get to my desired effect.
Tanx :)
19-38
39-48
