Full Version: Curve text
Show messages:  1-2  3-22  23-42  43-48
11 Sep 2009   [#3] In reply to [#1]
Hi Alberto, there isn't really any easy way currently to do that just inside of MoI alone.
Probably the easiest way would be to use a 2D illustration program to make text along a path and then import that and extrude it.
11 Sep 2009   [#4]
I would subtract the text in the center of the flower.
How can I do?
Margherita.3dm
11 Sep 2009   [#5] In reply to [#4]
I used the rotate widget in the V2 version. First I got the edge of the surface of the flower and translated it up a bit above the flower face. Then I moved each corner of the text block to meet that curve at its nearest point. Then I selected the text and moved the rotate widget to the touching point and then picked the raised edge and brought it down to meet the curve. Repeated for all text, then dropped it into the flower as deep as I wanted to go.
11 Sep 2009   [#6] In reply to [#5]
Many many many thanks !!
12 Sep 2009   [#7] In reply to [#6]
Hi Alverman,
I guess I should have posted the file "pre-Boolean" so you could have a better idea of what happened. If it's not clear, a video could be made to help see what the description is a little better.
For me, it's bed time now so if you post back, others can help or I will get back to it tommorow.
Nice work,
Burr
12 Sep 2009   [#8] In reply to [#7]
if there was the video would be very helpful :)
12 Sep 2009   [#9] In reply to [#8]
Here's a sample. It can be very precise. (Screen recorder makes it a bit more jumpy on my end)
Remember this is the V2 beta, so V1 wont do this.
Good luck.
12 Sep 2009   [#10] In reply to [#9]
Great video tutorial BurrMan!
14 Sep 2009   [#11] In reply to [#10]
Very kind Burrman !
Thank :D
30 Sep 2009   [#12] In reply to [#9]
Hi Burrman,
Just as an aside... what did you do to color your MoI icons? Are you using a custom UI?
Jesse
30 Sep 2009   [#13] In reply to [#12]
Hi Jesse,
I actually got them from Grnedel here in the forum. I think he just took the png files into photoshop or something and re-colored them. If you want "them" I could dig them up for you, or you could just hue adjust your own Icons however you like.
MoI's UI is fully customizable. Either by structure with html files, or by the images that are what you are seeing there with the buttons and such.
Before the beta's started rolling out regularly, There were some guy's working on "Custom UI" skins (User=ASH) that you could apply to MoI that were very cool. I think when the next release rolls out, you may see a couple of these come out again...
30 Sep 2009   [#14] In reply to [#13]
Hi Burr...
I am not familiar with Photoshop.
If I can, maybe I will convert all the MoI grey icon to colorize icon.
Maybe someone that expert in Photoshop can do this for us... :) ?
It will very good to have MoI with colorize icon.
Make the UI more fresh ;).
I forgot the link from Grendel.
Burr, have you the link or would you like to upload your color icons here ?
Many Thanks !!!
30 Sep 2009   [#15] In reply to [#14]
Hi Anis,
Here they are, courtesy of Grendel!
Put them into the UI\Icons folder. You may want to backup the original Icons in case you dont like it.
Again, once the release is out, there will probably be some customization that others do offered up in the forum.
30 Sep 2009   [#16] In reply to [#14]
Well seems had it wrong! The kudos go to lyes!!!
Same Icons you received before Anis. Here's the link:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2557.36&highlight=yes
30 Sep 2009   [#17] In reply to [#15]
Hi Burr,
I hope to have colorize icon for all MoI UI.
Wish user can contribute for this project.
Looks like Michael busy with scripting :)
30 Sep 2009   [#18]
About Photoshop you have a similar free one online SUMO PAiNT ;)
http://www.sumopaint.com/home/
30 Sep 2009   [#19] In reply to [#18]
Hi Pilou...
Thanks for the link.
Maybe we can also use software like Inskape or Gimp.
The problem is not on the appication that I have to use, but I dont know on how to use Photoshop to convert from GREY Icon to COLOR Icon.
It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
Then later I can convert another Icon by my self or maybe another MoI user can help :)
Thanks !
30 Sep 2009   [#20] In reply to [#19]
< It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
In Sumo Paint that is Menu Adjustments / Color Balance ;)
30 Sep 2009   [#21] In reply to [#20]
The thing to rememeber is it's not an "ICON" but a simple image in PNG format. Most photo software applications have an adjustment operation that will do something basic like this. You will just need the abilty to save it out as a PNG again.
Look for "color Adjustment" or "HUE" or something like that. Even the simple software that comes with todays digital cameras usually have the abilty to "Adjust" the image.
30 Sep 2009   [#22] In reply to [#21]
@ Pilou & Burr...
Thanks for your guide on how to edit MoI png to be more colorful.
I will create a new thread for collection of MoI Color UI.
Thanks ! :)
