Full Version: Curve text
Show messages:  1-9  10-29  30-48
12 Sep 2009   [#10] In reply to [#9]
Great video tutorial BurrMan!
14 Sep 2009   [#11] In reply to [#10]
Very kind Burrman !
Thank :D
30 Sep 2009   [#12] In reply to [#9]
Hi Burrman,
Just as an aside... what did you do to color your MoI icons? Are you using a custom UI?
Jesse
30 Sep 2009   [#13] In reply to [#12]
Hi Jesse,
I actually got them from Grnedel here in the forum. I think he just took the png files into photoshop or something and re-colored them. If you want "them" I could dig them up for you, or you could just hue adjust your own Icons however you like.
MoI's UI is fully customizable. Either by structure with html files, or by the images that are what you are seeing there with the buttons and such.
Before the beta's started rolling out regularly, There were some guy's working on "Custom UI" skins (User=ASH) that you could apply to MoI that were very cool. I think when the next release rolls out, you may see a couple of these come out again...
30 Sep 2009   [#14] In reply to [#13]
Hi Burr...
I am not familiar with Photoshop.
If I can, maybe I will convert all the MoI grey icon to colorize icon.
Maybe someone that expert in Photoshop can do this for us... :) ?
It will very good to have MoI with colorize icon.
Make the UI more fresh ;).
I forgot the link from Grendel.
Burr, have you the link or would you like to upload your color icons here ?
Many Thanks !!!
30 Sep 2009   [#15] In reply to [#14]
Hi Anis,
Here they are, courtesy of Grendel!
Put them into the UI\Icons folder. You may want to backup the original Icons in case you dont like it.
Again, once the release is out, there will probably be some customization that others do offered up in the forum.
30 Sep 2009   [#16] In reply to [#14]
Well seems had it wrong! The kudos go to lyes!!!
Same Icons you received before Anis. Here's the link:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2557.36&highlight=yes
30 Sep 2009   [#17] In reply to [#15]
Hi Burr,
I hope to have colorize icon for all MoI UI.
Wish user can contribute for this project.
Looks like Michael busy with scripting :)
30 Sep 2009   [#18]
About Photoshop you have a similar free one online SUMO PAiNT ;)
http://www.sumopaint.com/home/
30 Sep 2009   [#19] In reply to [#18]
Hi Pilou...
Thanks for the link.
Maybe we can also use software like Inskape or Gimp.
The problem is not on the appication that I have to use, but I dont know on how to use Photoshop to convert from GREY Icon to COLOR Icon.
It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
Then later I can convert another Icon by my self or maybe another MoI user can help :)
Thanks !
30 Sep 2009   [#20] In reply to [#19]
< It will be vey good if Iyes can give us tutorial on how to convert from Grey to Color Icon.
In Sumo Paint that is Menu Adjustments / Color Balance ;)
30 Sep 2009   [#21] In reply to [#20]
The thing to rememeber is it's not an "ICON" but a simple image in PNG format. Most photo software applications have an adjustment operation that will do something basic like this. You will just need the abilty to save it out as a PNG again.
Look for "color Adjustment" or "HUE" or something like that. Even the simple software that comes with todays digital cameras usually have the abilty to "Adjust" the image.
30 Sep 2009   [#22] In reply to [#21]
@ Pilou & Burr...
Thanks for your guide on how to edit MoI png to be more colorful.
I will create a new thread for collection of MoI Color UI.
Thanks ! :)
1 Oct 2009   [#23]
Sumo Paint has the PNG and then also the transparency for it ;)
1 Oct 2009   [#24] In reply to [#23]
Hi Guys...
A little problem when change the color of Offset.
When I pick the button it will go like this :
Normally in other default button is below :
Any clue... ?
Thanks ! :)
EDIT : Michael...., maybe you can split discussion that related to modify MoI Icon.
1 Oct 2009   [#25] In reply to [#24]
Just testing modify rect section, but got this :
1 Oct 2009   [#26] In reply to [#25]
Hi Anis, WHat you need to look for when you re-save your image is to set the "
Transparency color". WHen you do the save with PNG, there should be an option to set this, then use a color picker to set the background as transparent.
FYI.
1 Oct 2009   [#27] In reply to [#24]
Hi Anis,
It looks like it's got a solid white color for the background rather than a transparent background.
Like Burr mentions, the background needs to be maintained as transparent for it to look like the regular icons.
1 Oct 2009   [#28]
Hi Michael, I have I funny request, There are few icons are not include in the ui\icons folder. Will it be possible to have them also in there, in case someone like me wants to replace them? I know how to work around it but is a bit long to do every time with every Beta :(
1 Oct 2009   [#29] In reply to [#28]
Hi neo, no unfortunately I'm not able to put a few particular icons in the \ui folder because they are licensed from an icon collection and the license terms say that the icons must be baked in to the resources of the application.
For those ones you'll notice in the HTML where the buttons are defined, that the icon file name says res:// in it, that means to look up the icon from the compiled resources section of the program. You need to change those to point to your icon file when you want to replace those ones.
