11-25
Hi Danny,
> is there a way of determining arc length or perimeter length
> of an ellipses or any other irregular shaped curve, within MoI.
> A script maybe ?
There isn't anything set up for it currently, but I can add something in for the next beta that can be accessed by a script.
Michael,
The unwrapping that he is after would be if he had "Cylindrical stock" loaded into a machine that would rotate (or 4th axis) with th "Y" moves. So if you think of his flat surface as that, then he is on the right track but I dont think his theory allows for the extra length in the cylindrical unwrap.
Danny is asking the appropriate question which is something you answered for me and provided the functions to produce the conversion from the input values. I'll find the thread and post it for Danny. This was the "Draw arc by length" instead of degrees thing you answered for me.
Danny,
This kindof talks about it and methods for getting this value.
http://moi3d.com/forum/index.php?webtag=MOI&msg=2558.1
SO think of his CNC as having a table that moves in x,y,z.
X moves left and right. Y moves forward and back. And Z moves up and down. With a lessor software, it wants you to draw things flat, then it takes the Y value and makes that value "ROTATE" the workpiece. essentially making the surface of a cylinder "Flat".
Its different than the unfolding stuff for paper or sheetmetal. It's more a toolpath thing. And you cant "Unfold" a 3d model in this manner.
I hadnt tested his theory though. But if it worked that way, and it could be done on the cad side, it would be a much sought after tool! :O
The software he has now does this "Slab Slicing" also. Just as you explain here.
Hi Burr - I guess I kind of see.... But really I'd expect for that kind of process that is specialized to how a particular rotating machine works to be handled by a CAM program that knows a lot of details about how that particular machine operates and can analyze things appropriately for it.
MoI is focused much more on just creating the model data and not really directly on the machine interfacing part of the process.
I wish I could make MoI focused on doing every possible thing! :) But there is just not enough time available for me to make it do every possible function, especially ones where there are much more comprehensive programs available to focus on that area.
Maybe I still don't quite understand what the main purpose is - it kind of sounded to me like Gaston wanted to get a 4-axis type cut with CAM software that is only currently set up to do 3 axis stuff...
Thats basically it, I believe too. Most software under $10,000.00 doesnt do "true 4th axis". It does whats called "indexing" (just rotating the rotary by a provided value at some given point) or "wrapping", where they take one of the x or y values and convert it to an "a" (rotary) value. conversion axis*(360/(2*pi))/radius. The software does this conversion but in "2d". So drawing a circle that needs to be wrapped on a round bar is actually an ellipse.
to cut a 3d model, he needs to read his surface in 2d. I was kindof trying to answer him also with the previous post. The method he used to unwrap the model was cool but didnt take into account the "stretch" that happens with the conversion.
Anyway, thanks.
>>>>Hi Danny,
> A script maybe ?
I could use this also!
Thank you Michael and all. You guys are amazing :o)
I knew it could be done :)
Using Construct / Curve / Project allowed me to generate profiles easily. This is a big step
In the file attached you can follow the creation of the surface I'm looking for by lighting up objects in order.
Now I *only (:o) * need to find an automated way to move, rotate and position the sector profiles along the linear path line.
Is this possible? Any suggestions?
Gaston
3d shapeV1.3dm
Hi Gaston,
Sorry, no there isn't any automated way to take a radial arrangement of curves and move them along a straight line path.
It's still not very clear to me exactly what you are trying to do. Could you possibly give some more details on your equipment and your overall plan of how you want to produce your finished design?
Note that the surface that you are generating with the "straight line" arrangement is not identical to the original 3D surface - the distances between different peaks and valleys in your shapes is different in the "straight" one versus the 3D one, that produces different shaping when you loft a surface through the straight one for example.
So there is a kind of distortion happening with the method that you are using here, it is not actually a directly "unwrapped" version of the other surface.
Could scripts be helpful in this? I have not written scripts for Moi yet but I'm willing to give it a go if that may ease the process.
My machine has 3 axis to move the tool in space: X (left/right), Y (front/back), Z (up/down) and a fourth one, A axis ( 0-360deg) that rotates the stock.
In my setup,the stock axis is oriented parallel to the y axis, the X axis locked with the tool right above the stock axis. And the x axis info in sent to the rotating axis. The machine is set so the one rotation correspond to the linear path (object 4).
As the distance between the 3d ogject surface and the center is identical to the distance between the unwrapped surface and the center of the stock it seems to me the two should be identical, no? Of course more Intersection Lines would produce a closer lofted surface.
But you are probably right. I will need to cut a part to put my head around this one :)
Gaston
Gaston
Hi Gaston,
> the process.
Well, in theory yes, but I'm afraid that it would be quite a difficult task to produce such a script.
It's basically like you would be trying to create a toolpath generator. It's just overall the job that I would have expected a CAM program to be doing for you.
Ok, I think I understand what you are talking about a lot more now, thanks! :)
It's not so much about the distance to the center of the stock - it's about a difference in the distance between portions of each profile curve.
For instance when there is a depression, each projected section will be close to one another in 3D, but when you arrange these same sections in a linear progression, the spacing will be increased there.
How things are spaced is going to have some effect on the lofted result. So that's why you're going to have some difference if you try to use those linear arranged pieces to build a new loft surface through them. You'll probably tend to get different kinds of lumps and bumps in the shape because of that...
But possibly it will give you some kind of close enough result, I don't really know.
Ideally I guess you would never build a new loft surface at all and just take a whole bunch of radial profile curves from the 3D shape and use those as your toolpaths - but I always thought that is more or less exactly the kind of task that a CAM program is supposed to do for you?
Here is a screenshot of a cam package that does 4th axis wrapping. On the right, a 2 inch radius cylinder. The light blue is the cylinder unwrapped. Its Y value is not "4 inches". it is 6.2832.
Here it is in top view:
I can draw a circle and generate code and cut the circle:
but the software takes my "Y" values and converts them with this:
If I wanted to manually draw the same circle to feed to my 4th axis, it would look like this:
You would have to run a conversion on all your line geometry that would generate a "Y" move to create the proper shape.
Michael,
You are right, as far as I know, the CAM programs that support 4th axis would analyse the 3d object and the tool path but those CAM softwares that support 4th axis are way over my hobbyst budget.
My CAM program, as explained by BurrMan previously, is a "four side machining". Each side is machined in a raster fashion. The tool moves at constant speed across and within the boundary of the part and after each pass the other axis is incremented. During the whole process, the tool follows the peaks and valleys of the object.
One option is to machine the top part with normal xyz operation, rotate the part 90 degrees, machine the side then repeat for the bottom and the other side.
Colin told us that the Flow command in Rhino4 does exactly what I want to do (see the tutorial attachement to Colin's message 2654.8)
As Moi3d does not have such a command, my idea is to draw the object in 3d, then modify it so the CAM would "think" it is machining one side of the part while in fact the object would be rotated and the entire machining would take place in one operation.
Gaston
My idea was inspired by Julian Beever's sidewalk painting.
http://users.skynet.be/J.Beever/dungeon.html
Hi Gaston, what about this one:
http://www.imsrv.com/deskcnc/
It sounds like it handles 4-axis rotary type stuff...
It looks like the software is available for $250:
http://www.cadcamcadcam.com/software-deskcnconly.aspx
There is a demo version:
http://www.imsrv.com/deskcnc/dcncdown.htm
It may be worth checking out.
11-25
