Full Version: Flipping an object
1 Jul   [#1]
Hi group!
What is the most reliable and consistent way to flip an object (upside-down)?
I'm using the v4 trial version, not the v5 beta.
So far I can only seem to rotate. I have had a few times where the solid has moved 90º, but to get a 180º flip I'm not winning here.
1 Jul   [#2]
If you have straight snap toggled on the bottom task bar when you grab the object rotate widget in view it will snap to 90 and 180 when you rotate it
1 Jul   [#3]
You have also this transformation... depending of what do you want...
use other windows than 3D !
Result in real time in the 3D window !
1 Jul   [#4] In reply to [#1]
Transform > Mirror might be what you want.
- Peer
2 Jul   [#5] In reply to [#3]
Thanks Pilou! That's not only genius, but extremely elegant.
Perfect! :D
