Full Version: face names in exported step
Show messages: All  1  2-6
18 Jun   [#2] In reply to [#1]
@PEER
Edit :sorry i have read SVG for STEP ...sorry! But maybe the same trick can works :) (not tested)
The only way i have found for name something in SVG format is use the Color Style!
See my little section! ;) https://moiscript.weebly.com/anime-svg.html
18 Jun   [#3] In reply to [#1]
Hi Peer, it doesn't look like the STEP library tries to read or write a name attribute on faces.
Do you know of a program that supports it? If so can you make an example file?
Thanks, - Michael
18 Jun   [#4] In reply to [#3]
Michael & Pilou,
Supposedly NX, SolidWorks, and Fusion do this. I found the following example from an NX export on another forum:
#79=ADVANCED_FACE('LOADSURFACE1',(#55,#56,#57,#58,#59,#60),#44,.F.);
However, Pilou's RGB color code workaround might just work. I'll give that a try.
This is for marking boundary condition faces for finite element analysis.
- Peer
23 Jun   [#5] In reply to [#4]
Hi Peer,
I've updated MoI v5's STEP input/export so it should now support name labels on ADVANCED_FACE entities.
23 Jun   [#6] In reply to [#5]
Wow thanks Michael! That'll be a great help for data transfer.
- Peer
