Full Version: Object Cost > Script
Show messages: All  1  2-5
13 Jun   [#2]
About € against $ i suppose just to edit the file or it's more complicated ?
13 Jun   [#3] In reply to [#2]
hi pilou, yes that should work, let me know if it does not work as intented
or you want any other tweaks.. cheers stefano
13 Jun   [#4] In reply to [#3]
This is a clever idea Stefano, thanks for sharing!
I've also appreciated your CommandPalette, though have only been using v1.20 as it met my needs.
--Larry
13 Jun   [#5] In reply to [#4]
cheers for the feedback Larry,
i also like the one off scripts, the other one im using (a lot) is the curvelengths one i posted
few weeks or so ago (i think). i'll likely do a better modal window one soon...
re: command palette glad you getting some use out of it.
cheers stefano
