Full Version: Pivot Point issue
Show messages: All  1-12  13-20
20 May   [#13] In reply to [#12]
Hi Yanus3D, please try the attached .lwo , does it have the LightWave layers how you want?
whirlpool 2_lwo.zip
20 May   [#14] In reply to [#13]
Yes!
That`s correct export
One layer only.
20 May   [#15] In reply to [#14]
Hi Yanus3D,
> Yes!
> One layer only.
Great! To get that result, make sure "Combine same named objects" is turned on here under Options dialog > Import/Export :
Then set the objects you want combined to have the same object name before exporting.
To do that, use Ctrl+A to select all, then click on the object name here and set to any name other than blank:
If you then generate your .lwo file you should get the same one layer result.
20 May   [#16] In reply to [#15]
Yes, that`s works!
So I was thinking (I hate extra clicks in pipeline) is possible to do automatically?
Simple button in LW Exporter for it.....
20 May   [#17] In reply to [#16]
Hi Yanus3D,
Yes, you can set up a shortcut key that will do those steps automatically.
To do that go to Options > Shortcut keys and add a new one. For the Command part of the shortcut key put in this:
script:
moi.geometryDatabase.getObjects().setProperty( 'name', 'Layer' );
moi.geometryDatabase.saveAs( 'filetype=lwo' );
21 May   [#18] In reply to [#17]
Thank you!
But I am thinking about a fixed solution, such as adding a checkbox in the export menu. Could you add that?
There are too many procedures involved in exporting and importing, and I want to avoid unnecessary clicks and shortcuts.
I ask this because I understand when someone does it casually, but in our case, we have multiple projects running simultaneously, a huge data exchange between departments, and every extra click counts.
21 May   [#19] In reply to [#18]
Hi Yanus3D,
You only need to set up the shortcut one time, after that using the shortcut is just one key instead of 2 clicks.
Actually the shortcut saves even more clicks than that because it sets the file type to .lwo automatically as well.
21 May   [#20] In reply to [#17]
O yes...now works perfect :)
So I wait for next update with fixed Pivot.
Thanks again!
Can you make a list what I can put in script for Lightwave format?
