Full Version: Boolean
Show messages: All  1-2  3-20
17 May   [#3] In reply to [#2]
Hi Pilou
I don't understand the video you posted.
It has nothing to do with what I want to do.
17 May   [#4] In reply to [#1]
Hi Booleano, I'm sorry but I'm not understanding very much of this.
First off I'm seeing 6 objects in Green, not 3 like you wrote and the objects are stacked up on top of each other.
Next thing is I don't understand what you mean by doing a boolean difference to a specified dimension. Is it a 4mm radius fillet that you want to have that you are showing in CC.jpg ?
17 May   [#5] In reply to [#1]
If you're trying to create a "mould" I managed it by putting an exact in-line block for the boolean with the rear section
a single multi-block boolean failed for me
I presume the others would work this way too and then merge them.
Taladro.3dm
18 May   [#6] In reply to [#4]
Hi, Michael
I apologize for my mistake.
It's true that the 3 objects are duplicated, but to fix it, you just need to delete the extra 3, leaving only 3. Could you delete them? That way I don't have to send you the file again.
Thanks.
18 May   [#7] In reply to [#5]
Hi ado 1
Como he explicado a Michael, tenía los 3 objetos duplicados
18 May   [#8] In reply to [#6]
Hi Booleano,
Sure, but I'm sorry I still don't understand which thing is supposed to be 4mm.
Message 11997.9 was deleted
18 May   [#10] In reply to [#9]
11997.9 In reply to 11997.8
Hi Michael
This photo explains everything
18 May   [#11] In reply to [#10]
Hi Michael
Why does it have to be done on both sides of the file?
18 May   [#12] In reply to [#9]
Hola , Booleano
Un taladro está compuesto por numerosas piezas (aunque no quieras modelar las piezas internas que no se ven).
Antes de continuar con el modelado, sería conveniente, de cara a lo que viene después, realizar varias tareas:
- Nombrar todos los tipos de objetos que crees.
- Posicionar el taladro según los ejes X, Y y Z del software; esto permite gestionar mejor el modelado. Un taladro es, en general, simétrico con respecto al eje Z.
- Corrige algunas curvas de la parte central (en verde) que están distorsionadas; consulta las capturas de pantalla adjuntas.
A continuación, podrás concentrarte en la operación booleana que desees realizar.
Por mi parte, tomaría fotos (o las conseguiría si fuera posible) de las cuatro vistas de la taladradora para tenerlas como fondo en MoI 3D.
Pero no sabemos cuál es tu objetivo final?
Traducción del francés
Hello Boolean
A drill consists of many parts (even if you don't want to model the internal parts that aren't visible).
Before continuing with your modeling, it would be helpful for the rest of the process to complete several tasks:
- Name all the object types you create.
- Position your drill along the software’s X, Y, and Z axes; this allows for better modeling management. A drill is generally symmetrical about the Z-axis.
- Correct certain curves in the central section (in green) that are distorted; see the attached screenshots.
Then you can focus on the Boolean operation you wish to perform.
For my part, I would take photos (or obtain them if possible) of the four views of the drill so I can use them as a background in MoI 3D.
But we don't know what your ultimate goal is?
Translation from French
18 May   [#13] In reply to [#12]
Hi Zooen
Sorry, the file is corrupted. I'll correct it and resend it.
18 May   [#14] In reply to [#10]
Hi Booleano, looks like a quite difficult job to do by drawing. A reverse engineering tool would probably work better.
Do you have the actual object or only photos?
Some info:
https://wiki.mcneel.com/rhino/reverseengineering
https://blog.rhino3d.com/2026/02/mastering-scan-to-model-workflows-in.html
19 May   [#15] In reply to [#12]
Hi Zooen
How did you get that "transparent" image of the file so I can check for those defects?
I'd appreciate it if you could help me get it.
19 May   [#16] In reply to [#14]
Hi Michael
After trying many operations like copying and pasting and using two masks, I've gotten this far. I've attached the two files.
I think my difficulty lies in determining where to place the pivot point.
All images already published are valid
Thank you again for your help.
Hi
Well, I've finally done it
Taladro.3dm
Taladro_A.3dm
19 May   [#17] In reply to [#15]
Hello Booleano,
To answer your question, these aren't your three transparent solids. It's an extraction of all the edges from those three objects. The result is a wireframe of all visible objects.
To perform this extraction, you need to use the “SelectByType” script.
Below is a link with instructions.
http://kyticka.webzdarma.cz/3d/moi/#SelectByType
19 May   [#18] In reply to [#17]
Hi Zooen
Could you tell me how to type it "literally" so I can add it to my "Keyboard Shortcuts"?
It's not available on the website.
Thanks.
20 May   [#19] In reply to [#18]
https://moi3d.com/forum/index.php?webtag=MOI&msg=1106.1
20 May   [#20]
Hello everyone,
Thanks, Pilou, for posting this link.
I'm adding another link for Booleano, so we can save these scripts and plugins in a convenient location and have them available for every new MoI3D beta and new version of MoI 3D.
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11973.1
