Full Version: Boolean
Show messages: All  1-13  14-20
18 May   [#14] In reply to [#10]
Hi Booleano, looks like a quite difficult job to do by drawing. A reverse engineering tool would probably work better.
Do you have the actual object or only photos?
Some info:
https://wiki.mcneel.com/rhino/reverseengineering
https://blog.rhino3d.com/2026/02/mastering-scan-to-model-workflows-in.html
19 May   [#15] In reply to [#12]
Hi Zooen
How did you get that "transparent" image of the file so I can check for those defects?
I'd appreciate it if you could help me get it.
19 May   [#16] In reply to [#14]
Hi Michael
After trying many operations like copying and pasting and using two masks, I've gotten this far. I've attached the two files.
I think my difficulty lies in determining where to place the pivot point.
All images already published are valid
Thank you again for your help.
Hi
Well, I've finally done it
Taladro.3dm
Taladro_A.3dm
19 May   [#17] In reply to [#15]
Hello Booleano,
To answer your question, these aren't your three transparent solids. It's an extraction of all the edges from those three objects. The result is a wireframe of all visible objects.
To perform this extraction, you need to use the “SelectByType” script.
Below is a link with instructions.
http://kyticka.webzdarma.cz/3d/moi/#SelectByType
19 May   [#18] In reply to [#17]
Hi Zooen
Could you tell me how to type it "literally" so I can add it to my "Keyboard Shortcuts"?
It's not available on the website.
20 May   [#19] In reply to [#18]
https://moi3d.com/forum/index.php?webtag=MOI&msg=1106.1
20 May   [#20]
Hello everyone,
Thanks, Pilou, for posting this link.
I'm adding another link for Booleano, so we can save these scripts and plugins in a convenient location and have them available for every new MoI3D beta and new version of MoI 3D.
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11973.1
