Show messages: All
1-2
3-5
Is there a version that can be used with V3? Thank you.
Hi SUIYAN,
Sorry no the script access to the scene browser was added in MoI V4, that's the minimum version needed for this one.
Hi Suyan, i'd consider V4 so you can use V5 beta and all its improvements when you can.
In the meantime, this is a bit of a hack and it is not a 'toggle key' , Maybe
could be made one although with this version, pointless really as: its floating,
needs adjacent set and then the browser button pressed to minimise (so adjacent
panel is out of view).
So, if you can live with the scene browser floating or have two monitors might be "ok".
- It opens a floating scene browser on a shortcut key.
You would set options scene browser view to adjacent for this one to work.
options>general>scene broswer position>adjacent
Put
sidepane_V3_float.htm
file into moi 3 ui folder, here:
The shortcut command is:
script: moi.ui.createDialog( 'sidepane_V3_float.htm', 'resizeable,defaultWidth:260,defaultHeight:820' );
▶ Click to play video
Inspired by this (floating tool palette)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=9758.1Attachments:
Show messages: All
1-2
3-5
