Full Version: Flatten out 3D shape
6 May   [#1]
Is there an efficient way to 'flatten out' this shape? I need to get the top profile wire cut and need to have the entire shape flat so I can bend in the curves when I have the blank cut.
leaf spring.3dm
6 May   [#2] In reply to [#1]
Maybe something with the Flow function ?
Draw a line above your object
Project it
Unwrap the curve
Flow function
Difference on the view is perspective optic effect! ;)
6 May   [#3] In reply to [#1]
Hi Guy, you may need to rebuild the connecting area, it's kind of messy:
That comes from making an offset surface going around a bend where the offset distance is greater than the radius of the bend:
7 May   [#4] In reply to [#1]
Take a look at this post
https://moi3d.com/forum/index.php?webtag=MOI&msg=7406.1
7 May   [#5] In reply to [#2]
Thanks Frenchy and Michael,
Yes Flow worked nicely once I figured out how it works!
7 May   [#6] In reply to [#5]
i wonder if the edge flange script could also be adapted to work backwards and/or to take snapshots therefore
effectively having the memory to "unfold"
- not tried this script or flow functionality yet its been on my radar...
link to edge flange script..which i see as "folding tool"
https://moi3d.com/forum/index.php?webtag=MOI&msg=11523.1
