On the release notes post: [V5 beta Sep-17-2025 available now]
Michael's videos shows very easy to move face geometry or holes around a solid - i really like this but...
I then tried to select the same face - as the dialogue. top right also gives its diameter and height...
So is there a way to resize the hole in a single click with V5.
Not interested in deleting and recreating hole. Am interested in changing hole sizes
after already made part of a 'solid'.
Also tried transform "scale", that doesn't work either. Any changes effect the entire solid.
I'm planning on putting it in the "Edit size" menu that pops up when you click on that Diameter/height line but it isn't hooked up quite yet.
It needs a bit of an overhaul so it can work with multiple selection.
not quite got my head around isect yet but
was creating chisel tools by accident with a square and a circle (or 'hole')
- id have problems manufacturing your shape
wheres the Pilou tutorial on super-rapid ai renders - that would be good ;o)
Yep Nano Banana (20 images/ Day), Leonardo (150 images /day), Krea (50 images / day) etc... or other free IA replace all old and not so easy render engines! ;)
And if you overpass the day limite you can always make a snapshot! ;)
Some sufficient for a no pro usage!
Ps and you have so crazy real time render functions!
Of course all that is infinite exploration! :)
