Full Version: Moi 'loses' keyboard (linux)
Show messages: All  1-2  3-11
2 May   [#3] In reply to [#2]
If I remember right from a LInux terminal prompt put in :
wine --version
2 May   [#4] In reply to [#1]
Hi retrolenzil, another user reported a similar problem a while ago.
There is a "UseTakeFocus" setting in Wine that can be configured which solved it for them, give that a try.
Info here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11636.1
2 May   [#5] In reply to [#3]
Wine 9.0
2 May   [#6] In reply to [#4]
I'll give that a look. Thanks.
14 May   [#7]
Hi Michael.
Tried those links, sadly no change.
14 May   [#8] In reply to [#7]
Hi retrolenzil, according to https://www.winehq.org/ the current stable version of wine is Wine 11.0 .
So probably next thing to try is Wine version 10 or 11 with the "UseTakeFocus" setting applied there too.
6 Jun   [#9] In reply to [#8]
Late response but I upgraded to Wine 11 about two weeks ago. This made MoiV4 unusable. A lot of lag with selections, deselections, creation of geometry and features. No graphics errors but pretty much not usable for anything. MoiV5 beta runs better. Haven't used it enough yet to see if the keyboard issue is resolved, I will report back when I can say for sure. Just wanted to mention the V4 problems with Wine 11.
6 Jun   [#10] In reply to [#9]
Hi retrolenzil, for V4 try going to Options > "Edit .ini file" button and inside moi.ini in the [View] section, set:
GraphicsAPI=Direct3D11
Does that make V4 behave better?
7 Jun   [#11] In reply to [#10]
Tried that after I did the wine update. No difference. V5 seems fine.
