Full Version: remove 6 edges that don't do anything
Show messages: All  1-3  4-9
28 Apr   [#4] In reply to [#3]
brilliant - thanks.
...just downloaded the latest beta and am playing with it :-)
...are the files backward compatible with v4?
28 Apr   [#5] In reply to [#4]
Hi James,
Yes.
If you can please upload the .3dm file that would help me answer your other questions too.
29 Apr   [#6] In reply to [#5]
Thanks, Michael.
Here you go.
BE83 stand 23.3dm
29 Apr   [#7] In reply to [#6]
Hi James, there is a new "RemoveAndFill" function in v5 that can be used for this case.
You can access it by selecting the face:
Then use Shift+Delete:
It's also possible to do an "untrim" to erase a trim boundary to uncover the underlying surface. That's done by separating out a surface so it's not joined and then select all edges of a boundary and use Delete.
Some info on untrim here, but Shift+Delete is more convenient:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=9671.5
29 Apr   [#8] In reply to [#7]
thank you!
29 Apr   [#9] In reply to [#7]
This I like. That'll make my final cleanups way easier :)
