Show messages: All
1
2-9
Hi James, can you please post the .3dm file for the object you show?
Hi James,
> Question 3: related question: If I did create another cut-out there, is there a
> simple way to resize it (without removing it entirely and creating a new one)?
In v5 you can use the Transform > Move command on selected faces to edit openings.
Check out here for some demo screencaps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11803.1
brilliant - thanks.
...just downloaded the latest beta and am playing with it :-)
...are the files backward compatible with v4?
Hi James,
Yes.
If you can please upload the .3dm file that would help me answer your other questions too.
Thanks, Michael.
Here you go.
BE83 stand 23.3dm
Hi James, there is a new "RemoveAndFill" function in v5 that can be used for this case.
You can access it by selecting the face:
Then use Shift+Delete:
It's also possible to do an "untrim" to erase a trim boundary to uncover the underlying surface. That's done by separating out a surface so it's not joined and then select all edges of a boundary and use Delete.
Some info on untrim here, but Shift+Delete is more convenient:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=9671.5
thank you!
This I like. That'll make my final cleanups way easier :)
Show messages: All
1
2-9
