Full Version: remove 6 edges that don't do anything
28 Apr   [#1]
I can't quite remember how I got these (I was making a cut-out there and maybe removed it badly).
Question 1: how do I remove them? ...they aren't causing any problem per se, but they get in the way of my view as I will be putting another cut-out there.
- I have tried creating a 2nd solid that covers it and boolean-union.
- I have tried to separate and delete them but that doesn't work either (or I'm doing it wrong).
Question 2: Is there a cleanup tool to remove edges that don't impact the surface geometry?
Question 3: related question: If I did create another cut-out there, is there a simple way to resize it (without removing it entirely and creating a new one)? ...I think this may be how I got these edges in the first place.
Any tips greatly appreciated!
28 Apr   [#2] In reply to [#1]
Hi James, can you please post the .3dm file for the object you show?
28 Apr   [#3] In reply to [#1]
Hi James,
In v5 you can use the Transform > Move command on selected faces to edit openings.
Check out here for some demo screencaps:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11803.1
28 Apr   [#4] In reply to [#3]
brilliant - thanks.
...just downloaded the latest beta and am playing with it :-)
...are the files backward compatible with v4?
28 Apr   [#5] In reply to [#4]
Hi James,
Yes.
If you can please upload the .3dm file that would help me answer your other questions too.
29 Apr   [#6] In reply to [#5]
Thanks, Michael.
Here you go.
BE83 stand 23.3dm
29 Apr   [#7] In reply to [#6]
Hi James, there is a new "RemoveAndFill" function in v5 that can be used for this case.
You can access it by selecting the face:
Then use Shift+Delete:
It's also possible to do an "untrim" to erase a trim boundary to uncover the underlying surface. That's done by separating out a surface so it's not joined and then select all edges of a boundary and use Delete.
Some info on untrim here, but Shift+Delete is more convenient:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=9671.5
29 Apr   [#8] In reply to [#7]
thank you!
29 Apr   [#9] In reply to [#7]
This I like. That'll make my final cleanups way easier :)
