Show messages: All
1-6
7-15
In other words, it is more like a "Loft that creates curves instead of surfaces"!
MultiISO Could also be used to generate those loft curves. It seems that what is missing will be an automatic calc of the distance of the loft to get a count value to use.
i wonder If a script could do the step distance calc to get the count value?
I wonder if MoI's Loft Command could generate "Curves instead of Surfaces and solids"?
Project can be cool too! ;)
And as history is enabled by default you can adjust like you want!
Here one curve but you can move any number of curves in the same time !
Hi Matadem,
> This is the situation I would need.
Please try the attached version. This one will show the step distance if all the curves are planar.
cMorph2.zip
Nice!
That is exactly what I needed.
Now I can get things done faster.
Thank you!
Are you sure that "distance" is working ?
Number keeps the control!
Script shows 1.8...measures at 1.75mm
Good enough for me.
It was working in my tests. If you have a case where it isn't working can you post the .3dm model file?
Sorry not understanding this part.
Despit of any Distance entered number of curves is the only thing that work!
But maybe i don't understand what Cmorph2 is supposed to do!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/morph2.3dm
For this version that's normal. The request was to have the value displayed, not edited.
Show messages: All
1-6
7-15
