Full Version: Boolean
Show messages: All  1-4  5-11
4 Apr   [#5] In reply to [#2]
Hi
This is what I get when I click on the "Wire" and "Wire2" icons.
Please create a file with the three objects so I can see how it's done.
4 Apr   [#6] In reply to [#5]
Hi Booleano, that is saying that the Wire command wasn't found.
Does it work if you push Tab and then type _wire (with starting underscore) and push Enter?
If that works then you need to update your SidePane1.htm dialog box to have command="_Wire" (underscore at the start) instead of command="Wire". Same for _Wire2
4 Apr   [#7]
Else works fine! ;)
5 Apr   [#8] In reply to [#7]
Hi Pilou
It's fixed now.
P.S. Your render is beautiful, how did you do it?
5 Apr   [#9] In reply to [#8]
Hi Booleano, that message you are getting says that the Wire command wasn't found.
5 Apr   [#10] In reply to [#8]
As you see i have hundred of scripts intalled !:)
2 possibilities (for me) to Access
You have 2 more possibilities
- make a shortcut with _wire or _wire2 in the second column
or Press Tab and write _wire or _wire2
A big list alphabetical (my favorite) or an list of Images using follow for make the same than your but not practical! :)
as you see i have not image for the specific "Wire" ;)
Ps and more for me it's inFrench! :)
If you have your message it's because as Michael said you have not your Script installed ! in the commands folder!
Must be for Windows in the folder Roaming Moi / commands / _wire.htm & _wire.js ..._wire2.htm & _wire2.js
I suppose that will works also if they are in the direct Program / Moi/ commands
5 Apr   [#11] In reply to [#10]
It's either that, or if it is installed you've got the wrong name for it in your dialog box.
The button in your dialog box has command="Wire" but the actual file name is _Wire with an underscore in front.
