Full Version: splitting existing curve in equal points and trace?
Show messages: All  1-2  3-6
19 Sep   [#3]
Rebuild (bottom page)
then ReconstructCurve ? (top page)
You will have just "2 corner points" to resolve! :)
Or seems there is also something to make a curve from Points of Control points... I don't remember :(
change Control Points to Points then make curve from simple points :)
You can also Transform /Array / a Point to the original curve then make the curve by these arrayed points! ;)
19 Sep   [#4]
It may be easier to just use the import as a base and then redraw it like this.
19 Sep   [#5]
Tnx the reconstruct curve seems good.
The tracing works good ....I just want to make it a bit better.
25 Sep   [#6] In reply to [#5]
I use https://svgtrace.com/png-to-svg for tracing and then rebuild command if it's necessary.
Mik
