Full Version: Is there a way to zoom on screen to actual size?
Show messages: All  1-4  5-6
19 Sep   [#5] In reply to [#1]
Scan your gasket. Then you can bring the image into MoI and have a good ref for 50mm….
I also have these. They measure pixels, but you can measure known values then translate the values to calibrate your current display zoom…
https://www.iconico.com/caliper
I found Its kinof an odd attempt though. I think accepting that your screen is a digital representation and you can just trust MoI to give you accurate output is best
I ended up getting a Mitutoyo and other methods for real world measurements and just entering values. I was overthinking it….
19 Sep   [#6]
I know it is odd.
but my scanner is far away from my cnc computer.
So I just put the gasket on the screen for some odd shapes and get it done.
But I do have multiple ways of doing things....I do have a cnc probe..but sometimes it just takes too long..
I will be getting an old scanner in shop for these things,
Also installing a camera above my machines so it can auto trace with close enough measurements.
Ill just use what is faster.
tnx.
