How to make sure that MOI do not point to ..users/Appdata but on the root of the MOI3D directory ?
This concerns the objects library and scripts tabs which remain empty in the interface. (speak about Menu bar at the bottom of the interface)
EDIT : I use customui 2 beta 2
Phil
Hi Phil, if you create a folder named appdata inside of the install folder then MOI will use that instead of c:\Users\...
Then you can put the customui 2 beta 2 stuff under there.
Hi Mickael,
It was easier than expected
Thanks a lot :)
Phil
Message 11797.4 was deleted
