Full Version: Issues trying to run ImportPointFile Script
27 Aug   [#1]
I am researching 3D printing woodwind mouthpieces using a wide variety of mouthpiece examples.
I am trying to create a curve using a series of points collected using a Digital Indicator with USB interface. The goal is to be able to precisely replicate internal contours of real objects in MOI3D. I have attached the point file (X,Y,Z) in comma delimited text file format and a capture of the error message. Being able to get the script to run would be an enormous help and a great time saver.
By the way, this is the first time I have used a 3D printed tool that combines using a Digital Indicator for one axis and a digital caliper for a second axis at the same time to capture difficult to capture internal measurements in a depressed chamber. It's a real Rube Goldberg looking device but, works like a charm.... especially using a digital indicator with a USB output.
Thanks in advance for any help solving this issue.
Win11 Home
MOI3D 5 Beta
Tom
ChamberPoints.txt
27 Aug   [#2] In reply to [#1]
Hi Tom, please try this version here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5124.2
It says there that it's an update so it will work with the mac version , but it is also the one to use for windows version v3 or higher as well.
27 Aug   [#3] In reply to [#2]
That did the trick! Thank you... AS ALWAYS!
You are the best!
Tom
