Show messages: All
1-2
3-5
Hi MAT, also if the difference in z is small enough that it won't cause any downstream issues you can close it off using the Construct > Loft command instead of Planar.
To do that, select the 2 edges and then run the Construct > Loft command and uncheck the "Cap ends" option so it won't try to put end caps on it.
Then you can use Edit > Join to glue the pieces together into a solid.
The bottom will have a slight warp or something in it instead of being totally flat but it's pretty slight.
The other thing you could do is stretch out the inner and outer surfaces and then trim them with a common line at the level you want so they'll be on the same plane.
Hello Michael
thanks for the quick answer.
I see where the problem is, I used offset for the last operation and didn't snap it to the outer surface..
Is there a way to keep a tool live while typing the values? It would be easier to adjust..
Pascal
Hi Pascal,
It depends on the tool but often times things try to finish up when a value is typed in to reduce the number of operations needed to run it.
For curve offset if you are in "Through Point" mode it will finish when you pick the point. If you are in "By distance" mode you can adjust the distance, it won't finish until you pick a point for which side you want.
Show messages: All
1-2
3-5
