Full Version: Measuring things
Show messages: All  1-3  4-6
25 Aug   [#4] In reply to [#3]
Hi Steve,
Another alternative that may help since you mention measuring edges: select the edges themselves and either read the length from the Properties panel, or click Details and then click calculate length from the Curve properties.
--Larry
25 Aug   [#5]
I also use the line tool for measuring features. If you generate a construction line or two, you can also measure to notional points within the drawing. It's probably more useful that the usual measuring tools we see.
Martin.
26 Aug   [#6] In reply to [#2]
> "I just use a line"
Same here. Although...
> "...the length of the line is displayed in the "distance" field in the bottom command bar..."
...that is a good tip.
