Full Version: How to trim allot of pieces fast?
Show messages: All  1-4  5-7
21 Aug   [#5] In reply to [#1]
Hi Matadem,
> How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
21 Aug   [#6] In reply to [#5]
Or "Union" gives you the opposite side...
21 Aug   [#7]
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
