Show messages: All
1
2-7
In your special case
Maybe you have better time to make one losange module
then make an Radial Array
All makes maybe 2 seconds! :)
PS You must also put your object on the origin and not in the empty space of the galaxy! :)
Because some functions don't like this sort of thing!
Here is one....
Then using a surface and Boolean to generate the edges needed....
Hi Matadem,
> How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
Or "Union" gives you the opposite side...
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
Show messages: All
1
2-7
