Full Version: How to trim allot of pieces fast?
21 Aug   [#1]
Good day.
How would I trim these 48 pieces fast? I need to cut out the shapes out of the circle.
also thinking on this maybe in the future to get selection tools...like lasso , circular?
Tnx!
trimfilter.3dm
21 Aug   [#2]
In your special case
Maybe you have better time to make one losange module
then make an Radial Array
All makes maybe 2 seconds! :)
PS You must also put your object on the origin and not in the empty space of the galaxy! :)
Because some functions don't like this sort of thing!
21 Aug   [#3] In reply to [#1]
Here is one....
21 Aug   [#4] In reply to [#3]
Then using a surface and Boolean to generate the edges needed....
21 Aug   [#5] In reply to [#1]
Hi Matadem,
With closed curves you can use boolean difference which can speed things up.
Start with the circle selected:
Then run Construct > Boolean > Difference. The prompt will say "Select objects to subtract", select the diamond shapes:
You will then get this result:
21 Aug   [#6] In reply to [#5]
Or "Union" gives you the opposite side...
21 Aug   [#7]
The boolean union is that I needed.
but strangly when I was tried this earlier It did not go.
Tnx!
