Full Version: Duplicate Group at multiple points
Show messages: All  1-2  3-6
18 Aug   [#3] In reply to [#1]
Max Smirnov's vClone script here:
https://moi3d.com/wiki/MaxScriptArchive
20 Aug   [#4]
Thanks Guys!
CopyToPoints worked for me.
vClone seemed to want vector (maybe). I couldn't find instructions for it. If convenient, please advise.
Otherwise, I am set for now.
Appreciate the help.
20 Aug   [#5] In reply to [#4]
Hi MindSet,
Instructions here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
I think you're right that it wants to make duplicates that have different orientations so it uses lines and not just points.
20 Aug   [#6] In reply to [#4]
Yep it's for that you can use copy (your vector : a simple line) to Points ! For copy a vector to some points ;)
Then use VClone if you want different size and orientation of your base object!
Else Copy to Points is sufficient if you want only one or more same copy size of your base object!
Else very versatile! :) V SEED here
