Full Version: Which command for merging points on a spline?
Show messages: All  1-3  4-7
16 Aug   [#4] In reply to [#3]
Thank you Peer! Which spline type should I use to create the blending? I do not think that freeform by feeling brings a good result.
P.S.:
Hmmm´...chamfer is working...
16 Aug   [#5] In reply to [#4]
Hi Mala, the Blend command is here, under the Construct palette:
It can be used to create a smooth blend curve between the ends of 2 other curves.
They don't need to be on a common plane like curve filleting needs:
16 Aug   [#6] In reply to [#2]
I'm not 100% sure what your desired end result is but maybe select your curve and use Edit > Separate and delete these lines:
Then with some space opened up between the curves you can select 2 at a time and use Construct > Blend:
17 Aug   [#7] In reply to [#6]
Oh man!
Next marvelous thing, If I knew that before, it would save me so much time in my daily routines.
So now it will.
Thank you Michael for yet another discovery of hidden gems in your software.
Marek
