Full Version: Export as Step what is Bsplinesurface
Show messages: All  1-2  3-7
19 Jul   [#3] In reply to [#1]
Hi Matadem, what types of objects are you trying to export, is it stuff like spheres and cylinders?
By default those types of surfaces will export out to a STEP file as BSplineSurfaces.
But you can set an option so spheres will be a SPHERICAL_SURFACE in the STEP file.
To do that go to Options > General > "Edit .ini file" button and inside moi,ini find the section labeled [NURBS Export] and set the option in there WriteAnalyticSurfaces=y
I'm not sure if that is what you're looking for.
19 Jul   [#4]
I was trying to follow this tutroial > https://www.youtube.com/watch?v=U23eLLXuX3o
attached is a pic and the file I made to test it out and the Freecad.
Id can setup this in Vcarve within a minute.
setup tool database is way confusing in Freecad lol.
but I need to learn Freecad for the adaptive toolpath and fusion360 is no option for me with online/cloud stuff.
Tnx!
camt.stp
camtest.FCStd
19 Jul   [#5] In reply to [#4]
Hi Matadem, so if you set WriteAnalyticSurfaces=y inside moi.ini then MoI should write out PLANE surfaces instead of B_SPLINE_SURFACE_WITH_KNOTS.
That's what I did to make the attached version.
Does this file behave better when you load it into FreeCAD?
camt2.stp
19 Jul   [#6]
Ok it is showing some toolpaths so I am going in the right direction with the file you provided.
I am running some more tests tomorrow.
Thanks!
19 Jul   [#7]
Ok it works!
So I am going to play with it some more and do some test cuts....
I always think that Freecad could be a better program if it wasn't free lol.
I always follow its progress...
Thanks!
