Full Version: Twist on 2D
18 Jul   [#1]
I thought I remembered using this. Maybe it was in Corel or something else.
If not, maybe you can make it work somehow?
I would like to use "Twist" on 2d Profiles. So like if you take a shape like this and apply twist in the bounds center, the result should look like a "Hurricane" type of shape...
Twist on a 3d Object will give the appearance from the top view but the shape is obviously 3rd dimension. Can we acheive the same thing on 2D profiles? Currently it "rotates" the profile only with no Twisting deformation...
18 Jul   [#2] In reply to [#1]
Hi Burr, maybe a Flow with radial surfaces like this? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=7521.7
18 Jul   [#3] In reply to [#2]
Thank you. The #7 reply looks promising. I’ll fool around with it.
1 Aug   [#4] In reply to [#2]
Like a charm!
1 Aug   [#5] In reply to [#4]
Great! - Michael
