Show messages: All
1-2
3-8
I’m thinking the label could just remain as it is — simply “Split,” Michael.
Then, once in that mode, users could freely change the view type of
each viewport as they like. One extra thing that might be helpful is having
a way to reset the split view back to its default layout.
Thank you.
-Elang
Maybe click on the uper left view window said on "3D" for cycle view ? Pers, Ortho etc... so idem on Tab 3D...maybe just on the Tab 3D ?
Hi Elang,
The "Split" tab could remain as it is, but what about the "3D", "Top", "Front", and "Right" tabs?
Currently these correspond to a particular viewport. If you split the Top view for example so you now had 2 top viewports then how would the tab control react to that?
At first, I imagined that those buttons wouldn’t change at all — since what’s being changed is
only the view mode within the Split view itself. I just realized now that those buttons are actually
linked to the Split view layout… probably because I’ve been using your script shortcut for
switching views while modeling for a long time now!
But I suppose it wouldn’t be too difficult if the other buttons remained in their default state, right?
So that when a user clicks one of them, MoI would just take them back to the usual/default layout...
Though I’m not entirely sure about the technical side of this.
Thank you for your attention, and apologies for the delayed response — I just got home from work
(I’m in the GMT+7 time zone).
- Elang
Hi Elang,
> since what’s being changed is only the view mode within the Split view itself.
That's not quite right, what would be changed is that there would be new viewports introduced.
Currently there are 4 viewports. You can see all 4 at once in the tiled "Split" view or show one of them maximized with the other 4 buttons (3D/Top/Front/Right).
Well that's what would be pretty weird. Like if you created 6 viewports using the splitting mechanism that you're asking about but the view tabs kept pretending that there were 4 viewports without any connection to the actual current number of them.
Yes... you're right. Guess I was over-simplified matter too much. ^_^;
Show messages: All
1-2
3-8
