Full Version: Ask for help
Show messages: All  1-7  8-12
9 Jun   [#8] In reply to [#1]
Hi JINYICOOL, usually it's better to build a solid and then use filleting rather than constructing things one individual surface at a time.
For your case here you can construct it like this:
moi2.3dm
JINYICOOL_blend1.jpg  JINYICOOL_blend2.jpg  JINYICOOL_blend3.jpg  JINYICOOL_blend4.jpg
9 Jun   [#9] In reply to [#1]
Hi JINYICOOL, or another possibility is to use Construct > Blend.
To do that, delete this bottom piece:
Restore this plane:
Then you can select these edges and do a Construct > Blend:
9 Jun   [#10] In reply to [#1]
9 Jun   [#11] In reply to [#9]
Thanks, this gives me a new idea, and I think the mixed curvature result is smoother and more perfect.
10 Jun   [#12]
Dear all,
The NSIDED command will solve this particular problem. It can be found on Construct.
By using a GIF image, I will demonstrate how to do it. It's very easy to do. I hope you are able to accomplish it.
Ray.
