Full Version: Skew/Shear
Show messages: All  1-4  5-7
8 Jun   [#5] In reply to [#4]
Roger that - so I found that if a standard Surface is to be used as a base, it'll work the same as a Plane as long as I use Command>ShrinkTrimmedSrf first and adjust points accordingly
(obviously easier to use a Plane in the first place)
Those doggone points control everything ;)
5 Jul   [#6] In reply to [#2]
Seeing this has solved my quandary on how to italicize my custom font in MoI. I use MoI to make vector images - unusual workflow, I know, but I find it very easy to make shapes with compared to the likes of Inkscape - and have been making my own custom typeface.
6 Jul   [#7]
You have also an another transformations who can interest you!
Export PDF , Ai... "projection view"... from the 3D View ! + Orient Line-Line... for more results...
