Anyone know of a workaround for skewing/shearing a curve or solid? I've tried using the Deform function and these are the results; doesn't matter if I use a base curve or a base surface - the result is similar even after playing around with the Rigid/Stretch checkboxes
(this isn't the shape I need to skew - just an example)
Hi Raven, you can do it with a Flow using surface to surface.
If you can post your file that would make it easier to figure out what is not set up right.
I think your problem is you're using curve to curve flow which is meant to be be used more like a centerline path, not with closed curves like you have unless the object to deform was like a tube with the base curve and target curves at the centerline.
For this you would need to use surface to surface and not curve to curve.
Here's an example, I placed a plane using Draw solid > Plane (note, not Construct >Planar) , and edited its control points to make the target surface:
Select the object to deform, then run Transform > Deform > Flow and for the base curve or surface select the surface by clicking in this area, note not right at the corner, a little ways in from the corner along one edge:
Click the target surface in a matching spot like this:
That will make this result, set "Rigid" off if you had turned it on before:
shear_example.3dm
Aha - simple as that! Worked like a charm.
Yes, I did at first use a basic surface (derived from a closed square curve using 'Planar')
So what is the difference between a Plane and a square (or rectangular) Surface?
.....and once again Thank You :)
Hi Raven, you're welcome!
Construct > Planar makes a trimmed plane, you can see the difference if you select each surface and used Edit > Show pts to turn on the surface's control points.
It would actually be ok to make the square with Construct > Planar but if you tried to make the skewed surface with it that would not work for flow because the "underlying surface" of the trimmed plane is not skewed:
Roger that - so I found that if a standard Surface is to be used as a base, it'll work the same as a Plane as long as I use Command>ShrinkTrimmedSrf first and adjust points accordingly
(obviously easier to use a Plane in the first place)
Those doggone points control everything ;)
Seeing this has solved my quandary on how to italicize my custom font in MoI. I use MoI to make vector images - unusual workflow, I know, but I find it very easy to make shapes with compared to the likes of Inkscape - and have been making my own custom typeface.
You have also an another transformations who can interest you!
Export PDF , Ai... "projection view"... from the 3D View ! + Orient Line-Line... for more results...
