Full Version: Scaling including background images
Show messages: All  1-2  3-7
1 Jun   [#3] In reply to [#2]
I suspected that maybe the feature "embed image data in 3dm file" could be extended to that idea to scale the images together with the curves/objects.
If I have several images as background images and want to scale the whole file then I would have to scale each image single by single and align to the exact position. There could be always little discrepancies after manual scaling each image.
Such a script I guess would be of help. I don't know if the image would need to be shifted to its original position after the scale.
Thank you,
Axel
2 Jun   [#4] In reply to [#3]
Hi Axel, here's a TransformBackgroundImages script which has a move function and a scale function which will transform all background images together.
TransformBackgroundImages.zip
6 Jun   [#5] In reply to [#4]
many thanks!!
Thats really great, because it reduces discrepancies and saves time.
One request: is it possible to get it with undo ability?
Best regards,
Axel
10 Jun   [#6] In reply to [#5]
Hi Axel,
Unfortunately since background images are separate from regular objects there isn't the same undo infrastructure for them. So it's complicated for a script like this to support undo on them.
16 Jun   [#7] In reply to [#6]
thanks anyway for that script!
Best regards,
Axel
