Show messages: All
1-5
6-12
Hi Michal
is it possible at the end of the script to have it copy the 3dm filename into the clipboard also ?
cheers
shayne
Hi shayne,
Yes, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); } moi.copyTextToClipboard( filename ); }
Hi Michael
It copied the full path c:\to print\filename.stl
I just need the filename only if that is possible without any .stl or .3dm
shayne
Hi shayne, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { var basename = filename.substr( 0, index ); filename = basename + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
Thanks Michael
it errors
ReferenceError: Can't find variable: basename
line 1
1: >> var folder = 'D:\\To Print Morris and Watson\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
If its too hard to do don't spend any time on it
cheers
shayne
Hi shayne,
> it errors
It looks like you only copied the last piece of the above script?
You are missing this part in the new version above:
Try copying the entire script from above not just the ending part.
Works perfect thanks shayne
Show messages: All
1-5
6-12
