Show messages: All
1-10
11-12
Hi shayne,
> it errors
> ReferenceError: Can't find variable: basename
It looks like you only copied the last piece of the above script?
You are missing this part in the new version above:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) {
var basename = filename.substr( 0, index ); filename = basename + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
Try copying the entire script from above not just the ending part.
Works perfect thanks shayne
Show messages: All
1-10
11-12
