Hi Michael
I am using ver 4 (which is brilliant thanks)
Can you please write me a script that
saves an output file as my current file name
to a specified output folder ( it will always be the same )
as an stl angle 3
king regards
shayne
Hi shayne, are you on Mac or Windows?
Windows Thanks Michael
Hi shayne, here you go:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); } }
Edit this part:
to put in your output folder.
Note that to make a backslash character (\) there you will need to put in two backslashes because it's used as an escape character.
Hi Michael
That is brilliant thank you so much .
It will save me countless time every day
cheers
shayne
Hi Michal
is it possible at the end of the script to have it copy the 3dm filename into the clipboard also ?
cheers
shayne
Hi shayne,
Yes, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); } moi.copyTextToClipboard( filename ); }
Hi Michael
It copied the full path c:\to print\filename.stl
I just need the filename only if that is possible without any .stl or .3dm
shayne
Hi shayne, try this one:
script: var folder = 'c:\\scripts\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { var basename = filename.substr( 0, index ); filename = basename + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
Thanks Michael
it errors
ReferenceError: Can't find variable: basename
line 1
1: >> var folder = 'D:\\To Print Morris and Watson\\'; var filename = moi.geometryDatabase.currentFileName; if ( filename ) { var index = filename.lastIndexOf( '.' ); if ( index != -1 ) { filename = filename.substr( 0, index ) + '.stl'; filename = folder + moi.filesystem.getFileNameFromPath( filename ); moi.geometryDatabase.saveAs( filename, 'NoUI=true;Angle=3' ); moi.copyTextToClipboard( moi.filesystem.getFileNameFromPath(basename) ); } }
If its too hard to do don't spend any time on it
cheers
shayne
Hi shayne,
> it errors
It looks like you only copied the last piece of the above script?
You are missing this part in the new version above:
Try copying the entire script from above not just the ending part.
Works perfect thanks shayne
