Full Version: Proportional Editing for Moi's Organic Surface
Show messages:  1-14  15-34  35-47
24 May   [#15] In reply to [#12]
Thanks very much again, Pilou! :) I'd never heard of Nomad before, but it's already definitely 50x more natural and intuitive to use than Blender. I can't figure out how to activate Smoothing as a tool (and not just a general/global application), but maybe that option isn't in there if it's a free Beta version.
Thank you again - as this will really help me!
24 May   [#16] In reply to [#13]
That's true, Burrman. Creating solids/surfaces via a Loft or Sweep can also let you control the resultant object via the manipulation of points on those original lines/curves. But I'm not sure about this method using 'History Enabled', as I've never looked into any of that - so I look forward to your further illumination of that process. :)
24 May   [#17] In reply to [#15]
Yes some functions are disabled during the Beta!
You can use sculpt gl on line https://stephaneginier.com/sculptgl/
It's quasi the same and smoothing is Shift + mouse move over the object! ;)
24 May   [#18] In reply to [#14]
Here is 1
24 May   [#19] In reply to [#18]
Here is another.... I did surface and solid and enabled history in Deform
24 May   [#20] In reply to [#19]
And one with a surface that would be dense in points, but getting the "Soft Selection" with history on the creation curves...
25 May   [#21]
Same! ;)
Another one more elaborated by DanPerk
https://vimeo.com/370146519
25 May   [#22] In reply to [#21]
“””””same”””””
Actually, we are trying to demonstrate “soft selection” or “proportional editing”
The history allows us to edit the shape with a different set of points than the actual object, which can be 5 points instead of 500..
The flow was used to demonstrate how to get an already made mass of points surface to a state where it can be manipulated by a small number of points…
The challenge and ultimate use is to just manipulate the surface area of an object. Not really to deform a shape.
25 May   [#23] In reply to [#22]
Seems to me that will be exactly the same! ;)
I deplace only points of a surface ...target object can be any thing... a surface, a volume etc..
The secret is to select target result, call Histo and move Points ! And this at any time of the session!
(if target object not modified of course)
here a thick surface! :)
25 May   [#24] In reply to [#23]
""""""""Seems to me that will be exactly the same! """"""""""""
I was attempting to demonstrate "Soft Selection" or what the OP called "Proportional editing"
Not Flow history.
25 May   [#25] In reply to [#24]
OP's original image....
25 May   [#26]
Hi BurrMan, thank you very much for the videos! I subscribed to your channel right after watching them.
I understood the first two videos quite well, and I definitely learned something important about enabling and disabling history — I never realized it could be that powerful.
However, I didn’t quite understand the third one, especially regarding proportional editing. Are you saying that deforming is the only way to mimic Blender's proportional editing?
25 May   [#27] In reply to [#22]
Ahh… this one!
Now I understand the purpose of your third video — that’s a very creative way of thinking.
I’ll give it a try and explore further possibilities.
Thank you so much, BurrMan!
25 May   [#28] In reply to [#26]
“””””” However, I didn’t quite understand the third one””””””
The first 2 showed “if you were the creator” and keeping your curves to use with history (5 point curve for 500 point surface) you can get creative to “kindof” get what you want by moving a mass of points smoothy with just 1 pick point.
The 3rd one was me thinking “how do i apply it if YOU send me a surface with 500 points and NO CURVES.
So the 3rd vid is showing using flow and using a DUPLICATE of the mass point surface. In theory to get the “less points” to use.
But as an afterthought, i would still need to build a surface to gain access. I would probably attempt this with iso curves on the surface then rebuilding the curves to get simple curves to use. (If i could do that, that would eliminate FLOW!!)
So you got something out of it! We (and others) can explore more this for “scenarios” to see if its actually viable or false. Certainly not a replacement for poly soft selection but maybe a good lick in the toolbag?
Let me know…
25 May   [#29] In reply to [#28]
Sometimes, I need to make a minor modification to an organic surface created with MoI tools like Network, Loft, Sweep, Blend, etc. For example, from a surface blended between two edges, I might want to add a slight "bump" in the middle. In such cases, the quickest (and smoothest) way is often to edit the resulting surface points directly.
However, editing them one by one can be a tedious task — and that’s why I brought up the idea of proportional editing in my initial post, in the spirit of “organic surface explorations.”
Just like in Blender’s proportional editing, the idea is: when I pull a control point along its normal, the surrounding control points follow as well, but to a lesser extent — in a proportional way. That way, I wouldn’t need to manually adjust each point just to create a smooth bump. Doing it point-by-point would be quite impractical — especially, as you demonstrated, when an organic surface might contain hundreds of control points.
Your third video is brilliant. I learned something really valuable from it!
That said, for purposes like the one I illustrated above, the method still feels a bit unintuitive — at least for quick, exploratory shaping.
Cheers!
26 May   [#30] In reply to [#25]
Your third video with surface is like my last video and the use of Flow... :)
26 May   [#31] In reply to [#30]
Very different….
26 May   [#32]
Thanks for the other recommend, Pilou! Another much easier-to-use interface than Blender. :D
I'm still not quite sure I understand the techniques from your videos, Burrman, but I'll watch them a few more times and maybe it will become clear. Thanks very much for taking the time to show it all.
27 May   [#33] In reply to [#32]
Where are you stuck in the Burman videos ?
First is just move the Control points of the curves!
Don't kill the original curve when you have made a function! (here an extrusion)
About the Flow Function! You can take any volumes, surface etc...
Copy the "start" under surface
The littel trick is to select the object result then call the History! ;) Not intuitive but that works fine!
You can add points on the surface target before the Flow but object will be deformed...
(don't kill or modify the original Object and surface)
No more simple and speedy! (and i have an more 12 years old latop! ;)
30 May   [#34] In reply to [#33]
Oooooooooooohhhhh! I *think* I get it now. I've literally never used the "History" function up until now. I still can't quite understand how (in your screenshot/animated examples) the flat surface full of points is generated beneath the extruded shape. I can see a flat load of points when I select/add points to a flat shape, but they don't form a solid flat sheet/object like in your example and I'm not sure how to make it so. Is there something I'm missing?
Thank you very much for taking the time to show/explain it nonetheless, pal. :)
