Full Version: How to extend a screw thread?
Show messages: All  1-7  8-11
20 May   [#8]
Those Images are from one blender Tool that allow to make good aprox.
20 May   [#9] In reply to [#6]
"""""""""""""" I don't have any specs on this at all. The file was included in a 3d printing job. I had to modify a part to be larger which resulted in the screw being too short. """"""""""""""
Since you dont have any of the thread specs and the original prinyt and model were most likely modeled to fit, I woud approach your modification a little different
I would add a cylinder at the ID size of the threads to the part between the head and existing threads. Just need to be sure that the tensile integrity that will be slightly less, is ok with that method...
I will look at your model then attempt to separate the head and threads and make a bridge of 8mm in a poly modeling app.
I'll update later...
21 May   [#10] In reply to [#9]
Hey Bean,
So I ended up just doing this in MoI. I separated the threads from the head and created the 8mm gap, then i ended up with 2 solids.
I can put a "Pin" cylinder in between the 2 solids and Boolean it in to create a printable object. The pin should be smaller than the id of the threads to allow the threads to go deeper like you want,
A picture to illustrate. Your file back with 2 solids allows you to define your own "Peg/Pin" to extend the threads up.
21 May   [#11] In reply to [#10]
Here is the file. You'll have to let me know if you cant access it. Not a google drive user....
https://drive.google.com/file/d/1DddrzDzhtq9FL7keVJE2YqL7vaNyHouX/view?usp=sharing
