Hi guys,
I need some help. :) I'm trying to extend the thread of a screw to reach 20mm and am not sure how to achieve this. I tried to copy and paste the thread but cannot get it to match up perfectly.
If anyone can shed a light on it or able to do it, I have added the file to Google drive. I hate to ask but I just don't know how to pull it off :/
https://drive.google.com/file/d/1iu1tleD5zt9Pq3EAmiIet6GnaBZC44K4/view?usp=drive_linkImage Attachments:
Hi BEANZVISION, this file contains only triangulated model data.
It would be easier to work on the original CAD data instead of on triangulated polygon output.
Do you have the original CAD file for this part?
If not it would probably be best to reconstruct the threads, there are some posts discussing how to model threads here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=767.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=490.36
Also another one here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4623.1
It's because this data isn't the original accurate CAD model, the model you have here is a triangulated approximation.
Do you have any specs on it like what is the pitch supposed to be?
How accurate do you need it to be?
I estimated a pitch of 1.25 mm and just tried to eyeball the profile to make this attached version.
This was done using the method in the above links, with a helix path and a profile curve to sweep:
The result of the sweep is used as a cutting object in boolean difference against a cylinder:
20mm_bolt2_3dm.zip
It could be more accurate (and easier to make) if stuff like pitch, profile shape, radius, center point were given in a spec instead of trying to reverse engineer all of those from the triangle soup.
Thanks for taking the time to have a look. I don't have any specs on this at all. The file was included in a 3d printing job. I had to modify a part to be larger which resulted in the screw being too short. Yours looks extremely close so I will try and do a test print to see if it fits. :)
Those Images are from one blender Tool that allow to make good aprox.
"""""""""""""" I don't have any specs on this at all. The file was included in a 3d printing job. I had to modify a part to be larger which resulted in the screw being too short. """"""""""""""
Since you dont have any of the thread specs and the original prinyt and model were most likely modeled to fit, I woud approach your modification a little different
I would add a cylinder at the ID size of the threads to the part between the head and existing threads. Just need to be sure that the tensile integrity that will be slightly less, is ok with that method...
I will look at your model then attempt to separate the head and threads and make a bridge of 8mm in a poly modeling app.
I'll update later...
Hey Bean,
So I ended up just doing this in MoI. I separated the threads from the head and created the 8mm gap, then i ended up with 2 solids.
I can put a "Pin" cylinder in between the 2 solids and Boolean it in to create a printable object. The pin should be smaller than the id of the threads to allow the threads to go deeper like you want,
A picture to illustrate. Your file back with 2 solids allows you to define your own "Peg/Pin" to extend the threads up.
Here is the file. You'll have to let me know if you cant access it. Not a google drive user....
https://drive.google.com/file/d/1DddrzDzhtq9FL7keVJE2YqL7vaNyHouX/view?usp=sharing
