Full Version: V5 beta Feb-8-2025 available now
Show messages:  1-13  14-33  34-53  54-73  74-76
Message 11646.34 was deleted
1 May 2025   [#35]
Ah I'm getting errors uploading and NDA anyway but good to know it might be a video issue, yes just interesting it always seems to pop up with the import of a step...Hopefully just disappears with next beta. If I cut/paste the moi native effected geo in again it clears the problem up if that's any lead
1 May 2025   [#36] In reply to [#35]
Hi Rich, the error on upload will happen if the file is too large, like more than 10Mb.
For large files you'll need to use a file sharing service like WeTransfer, Dropbox, OneDrive, etc... where you upload the file there and share a link to it. You can e-mail the link to me at moi@moi3d.com if you want to keep it private.
What operating system are you running on?
If you're on Windows it would probably be a good idea to update your video driver to the latest version from the video card vendor's web site.
2 May 2025   [#37]
Hey - sent you a link to file cheers!
7 May 2025   [#38]
the .fbx import is misisng on this version
7 May 2025   [#39] In reply to [#38]
Hi binfordboy, since FBX files contain polygon mesh data and not CAD data, you can write out to an FBX file but not import it in to MoI.
Some more info on that here:
https://moi3d.com/faq#Q:_Why_can_I_export_to_.obj_format.2C_but_cannot_read_.obj_format_into_MoI.3F
The exception to that is if you are doing a sub-d surface conversion. In that case the sub-d importer is on the side pane under SubD > Create > "From file". That can process .obj or .fbx files that contain sub-d control cages.
21 Jun 2025   [#40]
Since we're in the middle of June, this particular beta build should be expiring soon, correct?
Asking because I lost track.
21 Jun 2025   [#41] In reply to [#40]
Hi Spartan,
If you look at help/About Moi, you will see Expires on Nov-28-2025
Have fun !
26 Jun 2025   [#42] In reply to [#41]
Got it.
Incidentally, is there a way to set an expiration date for the program so that it won't expire, or is that a server-side thing?
26 Jun 2025   [#43] In reply to [#42]
Hi Spartan,
Beta versions are set up to expire but the full version won't.
3 Jul 2025   [#44] In reply to [#43]
Allow me to clarify: I meant my question in regards to beta builds.
3 Jul 2025   [#45] In reply to [#44]
Hi Spartan,
Beta builds are designed to expire.
Once the beta test period is complete there will be a non-beta full release made and the full release versions do not expire.
Thanks, - Michael
5 Jul 2025   [#46] In reply to [#45]
Right, right. What I'm asking is how the programming handles that bit. Is there a specific file that contains the expiration date and relevant code? And if that's the case, can the files be modified?
Just curious.
(I'd also like to apologize if I seem like I'm not making sense. I struggle with phrasing my queries in a clear manner, as a neurodivergent individual.)
(side note: thanks for adding SVG import/export. I use MoI as part of my workflow for vector graphics and 3D animation, in addition to CAD. Adding SVG import/export makes it much easier, especially since I don't have to worry about any loss of data - and thus, potential loss of detail - when using intermediary formats like PDF like I used to.)
5 Jul 2025   [#47] In reply to [#46]
Hi Spartan,
Yes, it's part of the code in the main program module file moi_lib.dll .
Yes, it's possible to do that, it's called "cracking":
https://en.wikipedia.org/wiki/Software_cracking
But usually it's done by people who are distributing pirated versions of the software.
5 Jul 2025   [#48] In reply to [#47]
Gotcha.
Admittedly, I had entertained the idea of cracking - though:
A.) I'd put the kibosh on the idea after thinking it through, and:
B.) it woulda been for personal use anyway had I cracked it,
so there's that.
That said, my line of thinking often goes toward "can it be done" more than "should it be done" and "what are the repercussions thereof" - hence my asking in the first place.
14 Jul 2025   [#49] In reply to [#48]
Further question: is there (at minimum) one more beta build after this, or is V5's public release the next release?
(also, will V5 be the same price as V4 when it releases?)
14 Jul 2025   [#50] In reply to [#49]
Hi Spartan,
There will be at least one more beta.
Yes.
15 Jul 2025   [#51] In reply to [#50]
Right. Thanks. Just wanted to be sure.
3 Aug 2025   [#52]
Hi all,
It’s been a while since I last posted here—probably around 2012 or 2013.
I’m wondering: is there a non-commercial (NFS) version of MoI3D available?
€300 feels a bit steep for occasional hobby use.
3 Aug 2025   [#53] In reply to [#52]
Hi Rich, there is an EDU discount version available for students or teachers. Contact me at moi@moi3d.com for ordering that version, it's available from different resellers depending on where you are located.
There isn't any hobbyist discount version, sorry.
Thanks, - Michael
