Full Version: Onshape help
Show messages: All  1-3  4-16
11 Sep 2024   [#4] In reply to [#1]
Hi Psygorn,
> Also @Michael is it possible to have number of views exported as pdf (like selecting number
> of views for being exported as pdf) -I know it is possible to export pdf but is it possible
> to export multiple views at once?
Exporting multiple views on one page is not yet supported as a built in function but you can use the plug-in here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
That will generate a hidden line drawing with 4 views, and place the curves in the Top view and you can then export that to PDF.
11 Sep 2024   [#5] In reply to [#3]
Hi Psygorn, here's an example generated with Make2D4Views in MoI and then exported to PDF.
drawing.pdf
11 Sep 2024   [#6] In reply to [#3]
I upload inside Moi then export as STP
Import as multiple objects inside OnShape
and have that... top_part is the name of the entiere object!
PS
Same thing when importing as a single Object!
11 Sep 2024   [#7]
Export from MOI as Sat format!
Import format Sat as "single document" inside OnShape,
No problem! No error! ;)
11 Sep 2024   [#8]
Import your file from Moi in 3Dm format works but have some errors!
11 Sep 2024   [#9] In reply to [#5]
That looks promising for my needs, where can I get Make2D4Views? Is it a plugin?
-Psygorn
11 Sep 2024   [#10] In reply to [#7]
Aha! that's what I was looking for!
-Psygorn
11 Sep 2024   [#11] In reply to [#9]
Maybe there ? ;)
Make2D4Views
https://moi3d.com/forum/index.php?webtag=MOI&msg=8041.1
11 Sep 2024   [#12]
So for your object! ;)
11 Sep 2024   [#13]
For the fun... with the free Alpaca :)
As no prompt so curious result of course! :)
Just an image style...
11 Sep 2024   [#14]
Inside the free Vizcom who has a new version !
Automatic prompt!
and different renders
11 Sep 2024   [#15]
Thanks Pilou,
Thank you Michael.
-Psygorn
11 Sep 2024   [#16] In reply to [#15]
Else... :) Maybe not so easy than inside Moi! ;)
